I have installed an AilI battery monitor in my truck camper solar system. I am getting seemingly accurate Voltage readings but the current seems to be reading high as compared to the readings on my hand held clamp ammeter. ( used on the white or black wire only in the output wire between my inverter and the ATS ) I have viewed countless You Tube videos and I think I have it wired correctly, but I keep seeing the phrase " all negative load wires attached to P side " What are the negative load wires, where do they come from? From what devices or appliances do they have to come from. My inverter is wired directly to a stand alone ATS, which is wired into the back of the electrical panel There the green wire goes to a ground buss, the white goes to the neutral buss, and the black wire goes to the circuit breakers. Do I have to connect another wire from the electrical panel to the monitor shunt? They are at opposite ends of my truck camper. I am perplexed because I was able to understand how to put together the entire solar system which works great, but can't figure out what the " negative load wires " are. Any enlightment will be appreciated
