Many solar battery companies are selling 5Kw and larger self-contained battery banks (metal enclosures) with integral BMS, heat/cool management, connections, etc. in a metal case that can be assembled in parallel or in series. Also, many can now be monitored/managed using power management integration solutions from Victron, EPever and others.
What do you run? Are you planning an upgrade/replacement to more modular, vendor-built solutions?
I built my 15.5Kw battery bank around 48, CALB 100ah LFP cells in a 24v configuration (6P8S) with my own cabling, bus bars, hardware, Daly 500amp BMS and a plywood enclosure. My inverter/charger and solar charge controller(s) are Aims and have limited features/functionality. That saves on learning curve but I lose the flexibility to monitor/manage with Victron components. At this time, I use a Victron CCGX with the BMV712 shunt in order to remotely monitor the DC loads from my House systems and the charging/power from solar, shore power (grid) or on-board generator (all indicated as "DC Power" on the VRM app). I can also power the DC system from an Aims charger up to 37.5 DC amps if for some reason, shore power is limited to a single 30 or 50amp feed. My system is stand-alone and does not add power to the grid.
Today, if I were starting fresh, I'd consider three (or more) of the 24v, 5Kw rack mount battery packs from EG4 or equivalent.
My next big upgrade ($$$) will be to keep my CALB battery bank and swap in Victron suite of inverter/chargers, smart solar chargers, shunts and Cerbo GX with monitor. I will also upgrade to six, 490watt Heliene mono panels. The Heliene's are running about $215-220 (new, grade B).
I almost forgot, my solar is a set of 6, 250watt poly panels that, at peak are good for about 60amps. I rarely see peak. Normally, my peak is about 45amps on the clearest days. The panels are mounted flat on my 40' RV roof between the 'escape hatches'.
