Esutherliv
- May 31, 2021
- 9
So, I'm finally taking the plunge into small Solar projects for outbuildings.
The Current plan is a simple (hopefully) Cheap Conversion of a Steel Carport into an outdoor/kitchen Grill area. About the only thing I would need to power is some cheap Amazon LED Shop lights, a consumer radio, and probably charging ports for phones and the like.
The problem is, the day hours in the summer it's about 90-130f so most or really any events will be late into the night. Like 20:00-0:00/01:00
The other issue is I regularly get 125mph winds in a Special Wind Zone so I would have to go with a Beefed up Setup or possible off building set up. Also get Hail storms quite often
~ 12v system
Radio about 10w
Lights about 100w total
Small Water pump for sink 90w
60w USB Charger
The idea is to grab a cheaper 500w Sine inverter so I have some wiggle room but never really go over 200w MAYBE 300w. I'm thinking one of the Amazon Special 400w Deals and 2-200ah or 300ah lifepo4 batteries, a box to put them in and put it all in a closet in the carport. but I'm concerned if it would run for 4-6 hours or would I need a beefier set up?
~ 12v system
Radio about 10w
60w USB Charger
