Say what? How is a closed breaker going to arc over?" Acr over to where? By your logic systems will be arcing and sparking everywhere every time a BMS disconnects for whatever reason.
Totally different thing. Of course a contact "might" arc when opening. But in this case we are talking about a closed contact (the breaker) and the opening happening elsewhere (the BMS). The breaker is not going to arc when the BMS opens.
Depend if the gate-to-source voltage is high enough to arc across the gate dielectric.
The "contactor" might be the loose connection at the breaker terminal near the red wire.
Edit: To test it, just charge the battery at lower voltage 13.6 or 13.8v to prevent non stop BMS disconnect/reconnect due to OVP. If there is no heating.....then that is that. 3.4v or 3.45v per cell should be sufficient to get full charge for lifepo4
I already said the issue could be a bad crimp or a cheap breaker with resistance. However, it is still not going to magically arc across a closed breaker when the BMS opens upstream.
