FilterGuy
Solar Engineering Consultant - EG4 and Consumers
@Will Prowse recently did a 'cheapest 12V battery' video using a 250A Daly dumb BMS.
At the end of the video he talked about how well the BMS handled the over-current and then said he would never use it on a large system.....but did not elaborate.
I know there are downsides to the Daly dumb BMS. In particular:
So my question is this: Other than the above 3 points, what are the down sides to the Daly dumb if you are looking for a high current FET Based BMS?
- They do not have low temp disconnect
- They are not configurable. In general the Daly Dumbs set their High and Low cut-offs at the far end of what is acceptable, but if you are using the BMS as your last line of defense, that is not such a bad thing.
- The charge current is only 1/2 the discharge current.
