R Roswell Bob Solar Enthusiast Joined Dec 5, 2020 Messages 759 Location Warner, NH Aug 9, 2022 #1 Do the smaller passive balancers work ok? I have to wonder if a few hundred ma of balance current is enough to do the job.
N newbostonconst Solar Enthusiast Joined Sep 24, 2019 Messages 1,004 Aug 9, 2022 #2 Do smaller ones work? Yes to bigger ones work better? yes.... Might be better to say what you have or what you plan on using to see is people think it is going to work..
Steve_S Offgrid Cabineer, N.E. Ontario, Canada Joined Oct 29, 2019 Messages 7,782 Location Rural NE Ontario Canada Aug 9, 2022 #3 PPa
RV10flyer Solar Wizard Joined Mar 8, 2021 Messages 1,198 Aug 9, 2022 #4 newbostonconst said: Do smaller ones work? Yes to bigger ones work better? yes.... Might be better to say what you have or what you plan on using to see is people think it is going to work.. Click to expand... My JK with 2A bal works very well. The others about half of the time, even on the better quality cells. 0.015A does not do much.
4 400bird Solar Wizard Joined May 23, 2020 Messages 3,691 Location California Aug 9, 2022 #5 My 32 kWh pack stays balanced with 400mA of passive balancing. It's not even activating much. A pack with good cells should stay in balance without a balancer if any sort. But, life isn't perfect, a small amount of balancing is recommended.
R Roswell Bob Solar Enthusiast Joined Dec 5, 2020 Messages 759 Location Warner, NH Aug 24, 2022 #6 newbostonconst said: Do smaller ones work? Yes to bigger ones work better? yes.... Might be better to say what you have or what you plan on using to see is people think it is going to work.. Click to expand... I don't know exactly what it is other than a commercial application. I think active deign will be needed.
