themetallurgist
- May 18, 2022
- 3
Hello, I just got a new system system installed and I was curious if it is operating correctly or is my math wrong? I have 27 Aptos 440W panels with the Enphase IQ7A-72-2 micro-inverters. The max output of the micro-inverters is 366W. My system is producing 8.0-8.2kW at peak daylight, divide by 27 and that would be about 300W per panel. So where is the other 66W? I know there's some knockdown like the micro-inverter is 97% efficient, but 50W difference is significant. I should be seeing some clipping since the panels are at 440W (410W most likely). I was quoted a 11.88kW (10.766kW CEC rating) system, but on the drawing it says the system rating is STC=11.88, PTC=9.48, CEC=9.88. All panels are facing south, I live in north Texas, and my roof pitch is maybe 35 degrees from horizontal. Thank you for the help!!
