For a very basic "emergency electrical" off-grid system, I have a LMS 2430 controller.
In it's manual it lists 30A as max charge current and 30A max discharge current.
Using it with a 150w panel.
I have two 12v marine deep cycle batts that I want to connect for a batt bank for them. (I will connect them in parallel.)
Problem: I have just read that marine deep cycle batts don't like charging above about a 2A rate.
Is that 30A controller going to abuse these batts? Or is this one of those confusions between DC amps and AC amps?
If there is a possible problem with such a controller, then would it have a setting to limit the amps to a digestible level for the batts?
Any insight is appreciated.
