I am designing as system with 36 panels in 9-panel 450V 9A strings. I'd like to run each string back to a solark 15k instead of combining them at the source. The problem is that my shop roof where I can put the panels is almost 300' from the house. The solark has to be at the house where the service entrance is so I can net meter.
Do I really need 3 10 gauge wires per string? 12 THHN wires * 300' * $.64/ft at Lowes = $2304 in home run wire? That's 14.4 cents/kW just for the wire!
Looks like either schedule 40 or 80 1" conduit will meet code. Not sure I want to pull 12 wires through 300' of it though. A bit of the path is under a gravel parking area - does that mean 80 is required? For the whole length or can I switch once in the yard? For the schedule 40 I am seeing 1.70/ft for 1", 2.50 for 1.25" and 2.80 for 1.5". That's crazy for plastic pipe. And another $500-850 :-(
Is it possible to splice a THHN wire and use it underground? 300' wires from 500' doesn't work out very efficiently, so I would probably have to buy them all as 300' at by the foot pricing.
Thanks,
Jim
Thanks,
Jim
