JohnnyBravo
Angler
Hi,
I have the following LiFePO4 batteries:
1 x 40Ah from Liontron
1 x 84Ah from Liontron
1 x 100Ah from Victory
I want to connect them in parallel for running my stuff (mostly fridge with freezer, lights and TV) from AC (probably I'll get a pure sine wave 2000-3000W inverter).
Can you tell what wire size I should use to connect the batteries in parallel?
The size is selected based on the load surge power?
In case these batteries are not at the same voltage level, will they be damaged with their attempt to level their voltage?
Thanks
Thanks
