Dramacydril
Hi to all,
I need some help with the following 12v setup. I like to use this setup for led lighting / small radio / charging phone
1x JaaSolar panel 300watts
Voc 39.85 v
Vmp 32,26 v
Short circuit current lsc 9.75 A
Max power current lamp 9.30 A
Power selection 0~+5 w
MPPT charge controller 30 AMPS
12Volts - 50 AMPS Lifepo4 Battery
# Do i need to use breakers on this setup, if yes then what spec dc circuit breakers do i need and between where?
# i have some 2.5mm wire lying here that i want to use for this setup, spec for the wire is max. 4600 Watt/20 Ampère. Can i use this safely?
thanks for your time
Voc 39.85 v
Vmp 32,26 v
