road glide
I have a SMA Sunny boy GTI (SB5.0-1SP-US-41) with 6400w PV array. We are split phase 120/240v USA ...It is wired all conductors THHN-TNNN 8awg thru sched40 one inch conduit 80-90 feet to barn sub panel. 30amp DP breaker for PV array in the barn sub panel. Sub panel is rated at 100amp.
The sub panel is wired to the house panel 300 feet away with 4 AWG conductors in 2 inch sched40. ......50 amp DP breaker in house panel.
Considering adding two 6048 Sunny Islands at sub panel in barn storage area where panel is located. Battery bank would be in ventilated storage area near Islands..
I know my "41" can be used for OFF-GRID...but not battery backup...We just had another outage yesterday and one for 5 days a week ago in the California Sierra Mountains....If this keeps happening (especially this coming summer) I would code the Sunny Boy to "Island" and shut off the main from the Power company.
I have downloaded the SMA Sunny Island manual. (244 pages)
I've viewed many images of Sunny Island installs and the AC1 connections look like my 8 awg conductors...I have 8awg conductors from array to sub panel and those would need to be connected to the SI's for AC coupling, I believe...
Would be nice to use the solar trailer panels/modules to add another 2400k to my 6400) but my SB would clip out at 5k.
I am one of many who just bought a DC Solar trailer model "H"... 2014 model with 10 Talesun 240's, cabinet with 2 SI 6048's, MS combiner and charge controller and the usual 240/120 outlets. NO Kubota gen but I have a LP/Gas 11k (lp 7500 running) if need be...
Like the others I am currently nursing the GNB Tubular batteries(not classic) to see if they will come back....If not I will probably go to an AGM configuration....The trailer and equipment look virtually unused. There is no wear or tear on the cabinet, trailer, panels, tires...etc but it was sitting. When I got it the batteries have water just above the plates but testing with hydrometer and multi meter they are down below one volt....Should be 2-2.5v each cell.
So my question is:
1) Is my wiring conductors 8awg to the sub panel and 4awg to main panel sufficient?
2) Is there a way to wire both arrays to the SI's and have 8800 watts avail? I would leave the MS controller, combiner for the smaller DC trailer array..
PS...I know at some point Hedges will see this and I want to thank him and the forum for the valuable info the last few months
So my question is:
