G.W. Mad Scientist
AC side of the thread first. I'm wanting to run wiring from my breaker box to my transfer switch in my power room. I have a roll of 6/3 stranded copper. I was going to put that inside of some 3/4 " MC it seems to fit well with extra room and the MC slides over the 6/3 easily. My question is on my transfer switch I already stubbed 1 1/4 " gray PVC into the Attic if I run the 6/3 in MC from the breaker box completely into the transfer switch through the 1 1/4 " gray PVC will that still be acceptable as safe? Would that break any codes? Would be double piped for 3 ft from the attic into the transfer switch.( inverter is capable of 47 amps at 120v the generator will be capable of 40 amps at 240v)
Second part is on the DC side I'm going to be making battery cables to run from the Victron rs450/200 to my battery Bank. The Victron is capable of putting out 200 amps. I believe the inverter draw at maximum capacity is 176 amps. A friend gave me a roll of cable over 10 years ago that is battery cable of some kind. The roll was nearly empty from being a full roll but I figure there's got to be 20 ft or more. It's red and in the picture I'm comparing it to a 1/0 cable it seems to be 15% to 20% bigger would that make it 0/0 cable? The cable is not labeled at all... I'm thinking if it's battery cable and it's bigger than 1/0 shouldn't it be able to carry 200 amps safely? Last question, I'm going to be holding up a battery terminal that is a solder on I had some of these that were for 2/0 wire where can I find some like these for 0/0 cable ? I'd like to solder on my own ends and heat shrink wrap them. Thanks for reading and replying. GW
