reverse01134
Hello I am building 100ah power bank for camping uses. (diesel heater, phone charging, etc)
No need for inverter so it will be just the battery and 2 usb ports and 2 cigarette lighter sockets. For use of higher amp devices, I found heavy duty cigarette lighter sockets that support 12v 20a. I will add a switch to usb and cigarette lighter sockets to cut any idle wattage.
I have a few dumb questions…
1) Is 20a switch enough to handle 2 usb ports (12v 3a) and 2 cigarette lighter sockets (12v 20a)?
2) 20a cigarette lighter socket uses 14awg. Should I use 14awg for all connections? (Battery - switch - usb/cigarette lighter socket)
3) If I need to add fuses, where should it be located and what size fuse?
Thanks in advance for your help!
