I will be wiring up two sets of batteries in an open loop to two Sol-ark 12k's; a Fortress 18.5 and four EG4 Powerpro batteries all to a common busbar.
I have a few questions:
- I had the Fortress wired previously with a 4/0 conductor. The EG4's use 2/0 conductors. Should I leave the Fortress with the 4/0, or should I downsize that to match the 2/0 of the EG4 batteries? Does it matter?
- Do I wire each of the EG4's separately to the busbar, or do I continue to wire them to the one main EG4 battery and then run one conductor to the busbar?
- If I wire each separately to the busbar (which I think is best), are each of the cable lengths from the battery to the busbar equal length? My longest run would be 12 ft.
- Do I place a fuse between the busbar and inverters, or the busbar and each of the batteries? Any recommendation on which fuse to use?
