ZKETECH EBC-A40L manual configuration issue
windtrader
NorCal - Sacramento
Just received this battery tester and using via front panel only, no software configuration or testing.
The issue I have is when I set voltage in the charge or discharge panel, that value sticks across both pages. There should be two stored settings. Let's use 3.65 V for the limit on the charge screen and 2.5V on the discharge screen. Is that a know bug and the solution is to primarily set and control via software?
It states there is an auto test setting that will charge-discharge-charge, how is that possible if it does not store the max and min voltage levels?
Finally, is it just me who can not comprehend that manual? It is one of the worst in my experience.
