EG4 6000 XL won't communcate with the EG4-LL v1 batteries
PawneeOffgrid
Off Grid out on the Prairie
Nunn, CO
I bought two new EG4 6000 XLs to go with my EG4-LL batteries. I knew I would have to update the firmware on th batteries. Signature solar sent me the correct files and firmware (atleast I hope it was the correct firmware) and I successfully updated the firmware on all my batteries. I made sure that main battery was on DIP setting 1 and it still won't communicate.
After days with Signature solar trying to help they told me that the Inverters will NOT communicate with those EG4-LL batteries. Only the V2 batteries can do Lithium Ion Comms with those inverters. I have them running ok on the lead acid setting and the proper charge parameters but it seems odd to me that they won't communicate. Signature solar was adament that those batteries would NOT communicate.
Your thoughts? Ideas? Options maybe CAN bus rather than 485. I would love to get proper comms between my inverters and my batteries. I have 9 of them.
Pawnee Offgrid.
Seems odd. The LL batteries (if they have 6 dips) should be at setting 1; if there are 4 dips, it should be at setting "0".
Have you tried the CAN vs RS485 setting? I have the LL-S and I had to switch mine to use CAN. First, set the dips to "64" and then restart battery. Then hold down the "return" button for 5 secs to enter the settings. Choose CAN, then Lux. Then restart battery and set dips back to "1".
Pawnee Offgrid.
The EG4-LL V1 is expected to communicate with the 6000XP. I suggest testing both CAN and RS485 connections, but I recommend using CAN with the Lithium Brand set to number 0 on the 6000XP. Additionally, please confirm which firmware was provided so I can ensure it's the correct version for communication with the 6000XP.
The Firmware provided to me by signature solar came zipped in a folder named EG4-LL V1 Firmware-20231121T181806Z-001 And the hex file is named EG4-LL V1 multipack firmware.hex
If that is the right firmware, it does not work Via 485. I messed around with CAN bus but don't know what setting to set on the battery for the communication protocol. Any help you can give is much appreciated.
There are 4 dips and they are set to zero. My batteries done have the LCD screen to change settings on the batteries. So I am not sure how to change the batteries to CAN?
I believe that is the correct firmware from the naming of the file, however, I would make sure that the master battery is set to dip switch ID 1 for the LL model.
It is set to 1, and I worked with Signature solar for days and they finally came out and said oh they were wrong that battery won't communicate. SO I am desperate for some help.
Yes it will I tested this myself Please use this file
  • LL V1 Luxpower-20240220T194919Z-001.zip
Ok I got the master inverter to communicate to the first battery that I flashed. Now how do I get the second Slave inverter to not give me the sad face error. I set it to the same lithium setting as the master and I rebooted the slave inverter but it still gets an error message. I don't have a network cable plugged into the battery communication port on the slave inverter. Please Advise?
DM Me your Station
I cannot explain enough how grateful I am for the Forum and for Markus_EG4 he helped me get this all running correctly. Now in all seriousness, how do we get this solution over to Signature Solar so that they can server their customers better?
I am so damn happy to have proper comms between my inverters and my Batteries. Thank you thank you thank you
Ok one more question, I have backup system that has two of the new Lifepower 4 batteries on it. I could move the Gylls out to my Growatt backup system and move the Lifepower4 into the main rack if you think I would get the Lifepower 4's to communicate with the Eg4-LL V1 Chain?
Leave the gylls with the LLs they were made by the same engineers they work well together.
So I assume I should simply wire the Gylls into the bus bars in my server rack and let them operate without Comms? Giving me 900 amp hours even though the EG4 6000's only see the 700 amp hours? Sorry for all of the questions.
@SignatureSolarJess Markus_Eg4 was able to get my batteries communicating properly. Signature solar techs (Mr Greeley) was adament that my batteries would NOT communicate with the EG4 Inverters. How do we get this solution to your techs so that they can server your clients better?
Looks like we have more training coming soon
The bms on the battery will protect it and they will charge and discharge according don’t worry.
