NorthTown2022
So I purchased two identical JK inverter type BMS's from the same vendor, both came with a heat cable and both bear the heat code on the label.
I powered one up for the first time yesterday, did not look at anything and went straight for the update. I updated from v15.06 to v15.10. Unfortunately I didn't notice until afterwards while following along in one of Andy's videos that there was NO HEATING.
I fired up the second BMS still at v15.06 and It HAS HEATING activated in the firmware.
So is it possible updating from firmware v15.06 to v15.10 that I lost the heat function? or was the the first BMS ( now v15.10) never activated? I guess one sure way to find out would be to update number two .
I suppose my next step is to contact the vendor but first I'm curious to hear of anyone else's experience updating one of the heated models.
