Lifepo4 voltage drop recently
Wow, I think this has been very helpful. I hope this works have I damaged my battery by not charging it up fully for the last five months since I had it?
So right now my battery is at 13.37 volts on solar. Should I disconnect that and put it on 60 amp and take it to 14.4 V?
I only wish “Alberta lithium” was able to, or wanted to even help as much as you guys have.
Very disappointed with them.
Then my BMS is lying to me
Probably.
State of charge (SOC) indicators of BMSs will drift away from the actual SOC over time, especially if the battery is never really fully charged for a long time.
Many of them rely on a low or high cell or pack voltage warning state occurring before they reset the SOC to 0% or 100%.
If you want to track SOC with better accuracy then a quality shunt will help (but even they are not perfect). Else just make sure the battery gets a decent full charge occasionally so that the BMS is reset to 100%.
14.0 V is likely not high enough to reset the BMS SOC indicator but from a battery charge perspective, provided the battery charge current has tailed off then 14.0 V is plenty high enough and the battery will be 99.x% full.
LiFePO₄ is tricky chemistry to track SOC using voltage due to the voltage barely changing over a wide range of SOC (between 20-80% SOC there is not much change in voltage). As a result voltage is not a good indicator of LiFePO₄ SOC except when the battery is at a very high or very low state of charge - at the SOC extremes the voltage does change a lot more. With other chemistries such as lead acid, sodium and NMC then (no load) voltage more or less tracks pretty well with SOC.
This is why SOC sensors needs the battery to have achieved a full state of charge at the recommended max charge voltage with charge current having tailed off to a very low level.
Repeating what has already been said in a slightly different way... For a BMS to maintain accuracy, it needs to attain true 100% SoC about twice a month.
Additionally, you need to provide sufficient time above the balancing voltage to ensure the cells stay in balance.
Please post your BMS settings screens.
Please post your PV charger settings.
  • Your daily use is limited by your PV and available solar. If you use more than this, you will eat into your battery capacity, and you will eventually consume all your battery.
  • Your battery capacity determines how long you can go between charges.
It's important to know how many kWh/day you can collect via solar on good days and to understand how the seasons impact your available solar.
The PVWatts link in line #1 of my signature will allow you to compute your average daily solar hours by month based on your exact location, average weather and array orientation. If you have any shading or partial shading, it all goes to heck.
These are two apps I use I go back-and-forth cause I like to look at the gorilla one, but I don’t like looking at the blue one lol
Thank you so much ‼️
Here is a nice chart for reference. Keep in mind if you are charging or discharging the chart is lass accurate the more you are charging or discharging.
Also, I dont believe anyone has mentioned voltage settling.
You would charge to 14.4 until the current drops to basically nothing. Your charger may do this. (I hope you are not using a lead acid charger!!)
If you disconnected the charger and loads at this point., Do not be concerned if your voltage goes down to 13.8-14v. This is normal. This is called resting voltage and needs to be considered.
  • Screenshot 2024-03-24 at 16-29-14 Ultimate Guide to LiFePO4 Voltage Chart - Jackery.png
