For example, this should have been one post. Stop and think for a while before hitting the Post button.
The answer to your question is "it depends".
Since I do not know enough about your set up, use case and requirements, I cannot say.
If the system is going to be discharged daily, then recharge it to 100%. I would only not charge to 100% if the battery was going to be left for a long time without discharging it.
Then the question becomes how often is a recharge required?
If the system is a backup power source then charge every day after a discharge. That ensures maximum reserve capacity is available should it be required.
If it's not required as back up power source then it depends on how much energy is consumed during each discharge or each day.
But to provide some margin for error, do a full charge at some point when the battery is below 50% and above 10%. When exactly is up to you.
If you typically consume 10% of the battery per day, then you might only need to fully recharge it every 5-7 days.
If you typically consume 20% then perhaps every 2-4 days.
Or you could just decide to fully charge once it falls below 40% (or 50% or 30%). Up to you.
Ask the question - if I don't recharge now, will it make it through the next discharge session? Then add a safety buffer.
It won't hurt the battery. Used this way it will last for many
It won't hurt the battery. Used this way it will last for many thousands of cycles.
very awesome thank you
