Chio Antonius
I happen to have the perfect size generator the inverter suggests but the THD don't match!
I see the EG4 6000xp calls for a generator with a THD of <3% and I found out the GL11000 at 240v has a THD of 5.5%.
Any thoughts?
Generator has been running about 61.5 hertz and I know I can get it closer to 60hz with some adjustments.
The gen volts are a little higher than 240v also. I can adjust or may need a new AVR?
IS this damaging to the inverter?
How bad is it to run a higher THD than manual says?
My loads run fine and no warnings from inverter.
Any thoughts?
