Onehand
Outside of $2000 - $5000 inverter generator with low THD, (like less than 2 - 3%) what else can you connect to these inverters gen terminals?
I eluded to this in another post a while ago. Since I back feed the house mains with the generator, what I would like to do is run the inverter on grid/solar when power is available, if the grid fails, lock it out and feed the AC inputs on the inverter from the house mains being back fed by the generator, (if needed) using the same mains breakers already feeding the inverter.
Wonder if the AC inputs are any more forgiving with the ripple/THD than the gen circuit?
I am leary of doing this since I dont know how clean the power on the 12kw generator is and I don't want to cook anything in the inverters. In other words I'm not interested in trying it to "see" if it works at the risk of smoke.
The house load on the generator would be quite low, like 1000-1500 watts, if that. The rest would be available for the inverter and I could throttle the charging/bypass amperage but this still says nothing of the quality of the power. Guess I need to find a way to check the THD on this genset but from the vids I have seen, nothing out there is anywhere near the max numbers of the inverters spec. This plus, trying to determine THD is a bit of a hat trick, allot of variables and I dont know if any results would be accurate.
Wonder what EG4_jarrett on this forum would think?
