MaineHomesteader
I’ve seen a few posts on this in the forum but still can’t really make up my mind. We will be off grid and will be building a solar shed to house our setup. I think we want to go with PowerPro battery (one to start and probably add another later on) because they are heated. I’m also hoping to have around 8000w or so of panels. My big concern is which inverter to go with. The 6000XP says it only operates down to 32 degrees F. Even if our solar shed is insulated there may be an off chance that it gets colder than that. I really don’t want to have to run a heater in there either. The other concern is dust, I know the 6000XPs are pretty open and while we’ll try our best to keep the shed closed up, there’s a chance pollen and dust could end up in there. Which brings me to the 18kpv. Obviously it’s quite a bit more costly but it’s outdoor rated (and the warranty is better).
I would be willing to look into other brands that do well in cold climates too. I’ve been looking at Victron but having to buy all the other accessories to make the system functional is a bit irritating. I’ve also looked at Midnite, it seems like they also have some accessories but maybe not as bad as Victron. I also wonder about battery compatibility. Are there any inverters that wouldn’t be compatible with EG4 PowerPro?
Also another consideration. Do other companies allow for 120v charging with a generator? I have a 120v inverter generator and a 240v normal generator both are 4.3kw. I know there are small for battery charging but I really don’t want to buy another bigger generator. I would rather run the inverter generator because it’s more fuel efficient and quieter. I was eyeing the EG4 chargeverter which I could use for charging at 120v with a different plug. But would this work with non-EG4 systems?
