who is still burning wood in april?
Crane prob comes in handy for battery and generator shipments.
thats a long term lease unit I borrowed from my friends company on the weekends when they are not using it. works great for loading large logs... that biggest piece of oak there weighed in a 620 kilograms after sitting cut for 6 months.
I have a small forklift for batteries and other heavy stuff.
ha ha ha i have two 372 XP's a 365 SP with a 372 P&C on it and two 346 XP (both NE) and a T540xp. I go through some wood myself, but as I am only there on weekends not nearly like you. this is how I scrounge... 3-4 tons at a time.
NICE! This is my grocery getter.
Just switched to AC yesterday, but wood is still burning for hot water. Going to need wood for heat again next week, as we won't get above 60.
We're at 7000ft in the Rockies. It's supposed to be 30 degrees and snow 2 inches tonight, all our previous snow still hasn't melted. This global warming is killing me.
but but but but Al Gore and all of hollywierd riding in their private jets say its gonna kill us!!!! You must be scared! Obey! Follow our Rules!
Al Gore, Obammy and Joey "The Basement Rat" Biden would not lie to us would they?
I would still be burning wood year round, even in July, except that we super insulated our cabin and so the passive solar on sunny days is enough to keep the cabin at 70F and now that we, just yesterday, finally got our heat pump installed....no more wood burning until deep winter if ever again.
So far this Mitsubishi Hyper Heat has been awesome. Just sips power. Of course we've been dealing with ambient of only 30s and 40s so it's no longer cold, but keeping the cabin at 70F even on the past two cloudy days hasn't taken much electricity at all. Maybe 200Wh if that. I'd normally be burning firewood.
Off grid solar plus heat pump...my back already feels better...
May burning for me today. Probably could have made it fine with the Mitsubishi hp, but it rained an inch and the roof is a little leaky, so I wanted to dry it out a bit.
Damm temps dropped again, had to light of the stove just an hour ago. it got cold enough, quick enough that my split pack shut down automatically as it was too cold for the system to work properly.
Hasn't snowed here in almost 48 hours! Oregon Cascades. A warm 32° F this morning where lately it has been in the 20s overnight. The last wood stove fire of the season should be coming up in early July.
So you get about three or four months of non heating season?
Heated area is about 1500 square feet in Northern NH (if gets down to -20 F on occasion). 2x6 walls, double pane windows with double cellular blinds with side tracks on windows (an extra R 5). The tank usually gives me 24 hours, so I fire it once a day, but in cold conditions its twice a day. Total wood consumption is around 4 cords over a season. I use 1 ton mini split for shoulder seasons when overnight temps are over 25F. The house was built in 1987 as a modular and they definitely did not do advanced framing so lots of cold spots in the walls due to framing bridges. I did have an energy audit 10 years ago and with air sealing got the house down to point where I should have an air to air heat exchanger but do not so its tighter than most homes but nowhere near modern energy efficient buildings. To appreciably decrease the heat load I would need to strip the siding, build out the window casings and add 2 inches of foam on the outside, that would mitigate the cold spots, on the top and bottom header, window headers, corners and framing.
The big driver of storage tank thermal capacity is the type of heating emitters in the house. My house was setup for oil fired heat and has Slant FIn style hydronic radiators. Oil fired furnaces are usually set up to maintain a range of 160F to 180F and the radiator sizing is based on the same. The thermal performance of slant fin style radiators really drops off as the supply temps drop so if the tank drops below 140F, the amount of radiator surface area (length) is inadequate to heat the house on a cold day. My tank is vented American Solartechnics (great design but the owner has shut down the business and is selling it) with a PVC liner and its rated for 180F max. So I only have a differential of 40F of useful storage. At 8 pounds for a gallon multiplied by 40F delta that is 160K Btus storage. If I had radiant in the walls and ceilings, the supply temp using an injection mixer would be around 90F. 180F -90F = 90 delta so the same tank would have a capacity of 360 K. Note: due to stratification in the storage tank I actually have less capacity as 180F at the top of the tank may be 150F at the bottom. My tank is rough square. Horizontal cylindrical tanks will have even more impact due to stratification. Rectangular tanks take up far less room than cylindrical tanks but they still eat up some space. Folks with steel tanks may be able to tweak up to 200 F but they are flirting with boiling. I fire in the evening and the boiler is in the basement so I get a pretty good boost for several hours off the mass of the boiler and heat loss to the basement. The basement walls have 1" of foam outside but nothing in the floor so its is extracting some heat.
Most folks who have storage wish they had more with 1000 gallons being the sweet spot. Keep in mind that the storage needs to be matched to the boiler. My ancient Burham is rated at 100K btus/hr. For me to charge it up from 140F its going to take a couple of hours. My next system will probably use stainless steel IBC totes available on the surplus market, They can get up to 600 gallons and are rectangular with top manhole which would be good for installing a coil. I would buy two. I would just foam the exterior of the tank for insulation.
I ran across these this fall, 535 gallon and ASME rated. Cost was $600 each. I have another 370 gallon buffer tank, same height but slightly less diameter. I bought that for $175, too cheap to pass up. Expansion tank will cost me dearly.
Boiler will be an older Eko, the guy sold it to me cheap enough and threw in extras for free. He was 83 years old and his wife told him he was done burning wood. Eventual plan is staple up radiant on main floor of house, kids are moved away and we don't need to heat upstairs. I will add a coil to furnace for now, too many other projects to take up my time. Eventually I will add an air to water heat pump even though we can heat the house with the heat pump mini splits, I want that energy storage. I look at the tanks as just another battery.
