robbob2112
Doing more research, mosty harmless
You clearly have not done research.
Plugging your ears and screaming "la la la , i cant hear you" is not going to help (maybe it will make you feel good, but it wont change the reality or the truth).
This is similar to all the vaxx idiots screaming safe and effective and dying and having issues hand over fist, where even the official narrative is starting to admit that the vaxxes were anything but
Perhaps you should buy a block of land 50 miles from nowhere (make sure to check the cell towers and power line location and be 50 miles from them too.
Now dig a bunker 40ft below ground. Make sure to line the walls with 4ft of lead.
Make sure the steel is all pre-1945 - everything since is contaminated with radiation from the various bomb tests. They salvage WWII sunken ships to get this steel to use in medical equipment - it is very very expensive.
Move into it except you will have to use just oil lamps and such for your light and cooking
Make sure the air vents are baffled to keep the RF from traveling down it and put the fans on the surface.
Put your computer in a shack on the surface
Now you should at least be safe from RF... well except for ground waves.
You know the US government is constantly selling decommisioned missle silos - you could get one for yourself or just buy a condo in one.
