IanInShawnigan
Hello there
I am just asking around about my off grid system I just built.
Have you any idea how to deal with the EMF/EMR put out by the inverters when it powers up to run the fridge?
I recently bought a meter to test and found that the Pure Sine Wave inverter gives off massive emissions of EMF, over 200 milligouss!!!!
My system is in my basement. The readings are coming right up into the living room at 60+ milligouss which is deadly over time.
The system is grounded properly to the old house grounding rod through the floor in the basement that was no longer in use.
My 100% OFF GRID system is constructed of 6 Renogy Rover 40A Li MPPT controllers.
Each controller is hooked up to a 450W split cell (72) monochrystaline panel; 6 panels, each is independent from one another. They are all hooked up to 1 battery bank.
The battery bank has 18 - 6V AGM in series and parallel to make 9 - 12V, 250Ah for a total of 2250Ah and 1125Ah at 50% usage.
AGM is the safest and best way to go I believe from the solar experts I have spoken with.
At least 5000 cycles (15 years) and no off gassing or risks that lithium batteries have.
All 6 controllers are set at the auto identify factory setup as 12V, SLD. I have not changed anything in the parameters.
I am using a 4000W modified seine wave inverter, no EMF in the living room from that one, to run 4 small basement freezers and the upstairs fridge.
I began this learning curve almost 1 year ago and built the system over a few months.
I tried using a Renogy 3000W pure sine wave inverter but it gives off massive EMF through the floor and into the living room.
So, any ideas how to eliminate the massive EMF?
At the moment all I can come up with is dismantling the whole system and moving it into the garage which is not something I really want to ave to do![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Cheers from Vancouver Island, BC, Canada.
