AlaskanNoob
- Feb 20, 2021
- 913
Would this work to protect (fingers crossed) against solar flares and EMPs? I know it's not guaranteed and lots of variables, but the increased sun activity and the chance of solar flares knocking everything out has me a bit concerned given that we off grid solar types are so dependent on our silicon chip circuits and such.
So thinking a culvert like this one, except some rebar mesh in the floor, somehow attached to the culvert, and then some kind of mesh across the top with a door that can be opened and closed to allow stairway entrance into the culvert. With the door closed to complete contact. Then we'd put a wood roof on top of it which would be the floor for a shed. So final thing would be a shed with a faraday cage underneath it for storing generators, tools, backup solar equipment, radios, etc. Probably stored in aluminum trash cans for added protection.
I'd put some kind of foam or something on the inside to make sure nothing touches the metal structure.
If this would work, my questions are:
- What size rebar would I want to use for the floor (I'd be using it for EMF protection, not for structural reinforcement of concrete) and what kind of spacing for the grid of the rebar?
- what size rebar or wire for the roof cover and what kind of spacing?
- or should I use a solid metal plate for the floor and roof instead of having a mesh (this seems to be the best option, although not the cheapest, so I'm leaning toward a concrete floor that is smooth and level and then welding a plate for the floor into the culvert and then putting wood on top of that, and a metal roof except with a cut out door on hinges that makes good contact when closed)
The culvert metal is 10 gauge galvanized steel.
Many thanks for any inputs!
