AlaskanNoob
- Feb 20, 2021
- 906
The last time I posted on this forum about a design plan, I also had no idea and no experience with the subject matter. Of course that was my plan for solar. After years of getting educated, the solar we finally installed this last summer looked absolutely nothing like my original plan. Nothing.
This should be simpler, although I am still ignorant. I have no experience raising rabbits or chickens. With my design here (very poorly drawn up to simply convey the basic idea), I am hoping to a) allow the rabbits/chickens to graze and b) protect them from the over abundance of things out here that want to eat them.
I'll show my Rabbit Run idea here. The chicken coop idea is essentially the same, except the part where the rod comes up from the ground will go through the middle of a small coop with nesting boxes (which will be wider than the run).
The idea for both is that I have a long, narrow, run that will have a motorized wheel on the outside end of it, some electric jacks, and it will rotate the entire run in a circle. The run is 100 square feet (just picked that size for now, that will likely change) and is 50 foot long and 2 foot wide. On some interval, the jacks will lift the run up off the ground (I'm not sure how yet) and the motorized wheel will drive the run along the circle for about 2 feet, and the jacks will let the run back down. The wheel(s), motor, and jacks are not shown in the sketch above, nor is the very steep metal roof or the thick mesh / chicken wire walls. Or the large mesh floor that will hopefully allow the plants to come up through it, but prevent the rabbits from getting out. No floor on the chicken version though.
The goal is to build a relatively small run, but have that run enjoy a 100 foot diameter field of planted food. Which is .18 acres of food. I'll start the project by clearing out a level 100 foot diameter circle and then planting concentric rings of perennial plants in a manner that provides the right balance of nutrition for the critters. So in the run, they'll have the right amount of plants to eat. Then at night when the rabbits are sleeping and not in the run (they will have an artificial warren I'll bury nearby with a tunnel to a hole center-located with the rod, so that they can always access the run), I'll program the run to move over to the next 2 foot wide slice of the field, so when they wake up they will have fresh food, and the plants they were eating the day before can begin to recover.
I'll also have an electric "door" that can protect the access hole to the warren to either protect them from an ermine that manages to get past my defenses and into the run, and can cut them off from running back into the warren when it comes time for me to make fried rabbit for dinner.
When there is snow on the ground, the system will stay put and I'll be feeding them the old fashioned way.
I haven't seen anybody do this for chickens or for rabbits, so maybe my idea is as dumb as my initial solar plan. But building a 100 square foot structure that allows the varmints to eat 8000 square foot of garden planted for them seems like a pretty good idea if I can pull it off. Thoughts?
