Simpleone71
I have read numerous posts on how the BMS is not super accurate at calculating the SOC, especially in cases where the batteries are not fully charged every so often.
I currently run on my batteries 100% of the time and let the solar recharge the batteries. If there is not enough solar energy, the grid will charge up the batteries by 30%, so hopefully, the next day, the solar energy can pick up. I'm adding two more solar panels, but it will likely still not be enough to charge the batteries to 100% each day fully.
So the way I use my batteries, it is likely they will not see 100% SOC for a while. This has already caused my BMS to show 44% and my Victron Lynx Shunt is showing 53%
Should I change my Cerbox GX to use the Lynx Shunt as the battery monitor instead of my EG4 LL-S BMS? I have attached the current status from VRM.
