Philpo
Hi All, I am building a small 2.6KW system for my home office / garage (6 x 425w solar panels, although I will probably expand it with more panels at a later date).
For an inverter I have a Growatt SPF 5000 ES. This unit cannot export energy back to the grid (I don’t want to with this small set up), but does have an AC input which allows for pass through energy from the grid to charge the system battery and also provide power for running applications (when the sun doesn’t shine etc) through the AC output.
To install the inverter, the manual recommends putting a 50 amp circuit breaker BEFORE the AC input.
AC input for the unit would come from a power cable that runs from the garage consumer unit (on the other side of the garage). At present this cable runs across the garage walls, out the garage, and under the ground, to power our small garden office (which has about 12 standard double wall outlets).
Does anybody have any recommendations on what kind of AC breaker to use (specific brands/models would be helpful)? Would it be suitable to put another garage consumer unit with a 63 amp RCD (I think that’s what the garage consumer unit has) and a 50 amp breaker before the inverter?
I hope this is clear, I’ll try and clarify further if needed.
Thanks in advance for your help, you guys rule![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
