douglasheld
Hi all, in my garage I've installed a simple off-grid 12V solar energy storage system.
I've long been intending to install LED lighting strips, specifically 3x this product: https://www.aliexpress.com/item/100...der_detail.order_detail_item.3.5674f19cuHIMrq
I've tried wiring this up to the battery supply through a 2A fuse. It is quite bright of course, and I measured that it draws about 2 Amperes.
With my Arduino projects I have a set of little resistors of all sorts of resistance, from 1Ω up to 100KΩ. But, if this poor resistor is going to pull up to 2A, that's 24W and I think I might fry it. At the same time, the very presence of the resistor means less current is going to flow and the power draw will be less.
I can't quite get my head around how to work out how bright I really want this lighting to be. Right now I've just measured out the cabling and pulled the fuse until I buy the rest of the parts. I will need a off switch, possibly a dimmer knob, and one or more current limiting resistors. I have up to four strips (of the length you see in the photo) that I can install.
Thanks if someone can recommend a shortcut to spending 9 hours standing on a chair, attaching and replacing a hundred resistors until I'm happy with it?
