OK, my batteries arrived (3.2v 280ah lifep04).
Just confirming the rate and intensity they should be balanced at On a YouTube video the dude says put them in parallel, set the charger to 3.6v and crank up the amps until there's no current going into them, and this will mean they are balanced. Is this correct? Why not 3.2v?
Also, I have a configurable charger that I will run from a generator (if the bank gets too low at night). Should the bulk and float charges be set to 3.6v?
Thank you very much.
