sprinter99
- Oct 29, 2020
- 18
Hi!
I am building a 24V system and bought 4 LG Bi-Facial panels but I am having issues trying to decide which on to buy. You could say im a bit of a beginner in bigger sized system. I only worked on a 300w 12v van system before
The Panel specs are
Peak Power: 520 Wp
Voc (V): 49.8
Isc (A): 13.29
Vmpp (V): 41.6
Impp (A): 12.51
NOCT: 45 ± 3 °C
Module efficiency (%): 24.6
Maximum system voltage (V): 1500 (UL) / 1000 (IEC)
Maximum series fuse rating (A): 20
The salesman said I needed a 250/100 from victron ? would a victron 100/50 do or outback 80 ? would i need to connect them parralel to choose a smaller controller ?
anything helps !!
The Panel specs are
Peak Power: 520 Wp
Voc (V): 49.8
Isc (A): 13.29
Vmpp (V): 41.6
Impp (A): 12.51
NOCT: 45 ± 3 °C
anything helps !!
