Batteries year round will see 65-72f.
Hoping to charge between 65-75%
Based on increase in cell life.
I was thinking of doing 16s by 8 as the diagrams were readily available and easy to follow. I kept
finding that the recommend charging is to be done by the inverter charge controller not the bms. My thoughts were
that having 8 batteries and not using the bms for cutoff could be problematic. Since yesterday I have been trying
to find different battery configurations and stumbled upon the 16S11P but I'm unable to find a diagram
on wiring this battery. If the math is right this is a much better configuration and creates a single battery
which has a much higher kwh rating. My inverter and extra charge controller require 48v.
16s
16128.0
129,024wh
16S11P
177408.0wh
If anyone has suggestion on battery configuration or it doing a 16S11P would not be the right way I would appreciate any help.
I have emailed orion, chargery and batrium, orion support is great and very helpful, chargery was also quick to respond. I'm still waiting on
and email from batrium but two emails have not been answered. I like the idea of active balancing and leaning towards batrium but wanted
to confirm if I can use with my configuration.
![batteryuniversity.com](https://batteryuniversity.com/img/content/_400x400_crop_center-center_82_none/bu-social.jpg)
16s
16128.0
129,024wh
16S11P
177408.0wh
