Hi.
I am hoping to learn as much as possible about solar charging systems so that I can in some way reduce my dependence on grid energy .
Eventually, I would like to have my workshop powered by off grid power but before that I would like to learn-by-making a smaller project.
The project I have in mind involves placing motion activated led lights at critical points in my home, so that after a certain time ( night time), when I move around my home I would not need to turn on grid energy ( this would also be useful whenever there are power outages in my area).
The project would involve 6 led lights of 5 watts each and I have estimated that an average daily load of 7.5 watt hrs per day.
apparently I should estimate my pv panel size based on the estimated watts hrs per day divided by the number of hours sunlight most likely in this part of the world (Ireland) during summer (4 hrs) and winter ( 1 hr) giving me a maximum required panel size of 7.5 watts
This I realize is just not practical so I,ve decided to get a 25 watt panel and allow for a lot less sun!!!!!.... this is Ireland after all!!
details of the panel are:
Pmax. 25W
Vpm: 17.9V
lpm: 1.4A
Voc: 22.41V
lsc : 1.54A
I have also bought a solar charge controller to go with the panel.
Solar Charge controller details:
PWM
12/24V
20A
built-in timer
full ptotected
settable voltage
usb
self-consume <10mA
float charge 13.7V ( default.adjustable)
discharge stop 10.7V ( default.adjustable)
discharge reconnect 12.6V ( default.adjustable)
my intention was to connect a power inverter ( pure sine wave ..... so that it can be used on digital gear after this project) and run the 220 v led bulbs using 220 v twin and earth wiring rather than using 12volt wiring and fitting .
after finding an inverter that was small enough (Victron energy Phenoix 12 /250) discovered that the minimum battery size needed to use with this inverter was 30 Ah which was considerable more than the 9Ah battery my initial calculations suggested I needed.
If anyone has any advice on how I might alter my design to achieve my goal , I would be really grateful.
Best wishes and stay safe
EdK
Pmax. 25W
Vpm: 17.9V
lpm: 1.4A
Voc: 22.41V
lsc : 1.54A
PWM
12/24V
20A
built-in timer
full ptotected
settable voltage
usb
self-consume <10mA
EdK
