we Travel full time in an RV and since we’ve owned it whenever the water pumps run the lights flicker. This is because the pumps pulse in and off etc. I read somewhere to seperate the lights and water pumps. My pumps are directly next to my batteries so I could do this rather easily, however, I’d like some advise on how to sepeareate them. As it stands the water pumps and lights are already on a different fuse (inside a 12v fuse block).
so in my logical brain if it pulses inside the fuse block how does separating it stop the flickering. The pumps and lights always come back to the same origin?
perhaps I’m missing something.
I assumed I could install a power distribution block straight off the 24 to 12v converter and run the pumps from one pole here. But will this actually fix my issue?
