There is a similar question already posted but this one contains some different details (and I don't want to remove the existing RV converter box).
I have an RV with a 120v system and a 12v system. The 12v water pumps, fans and lights are not very power hungry but there is a 12v refrigerator that runs at about 125w. To operate off grid I will be installing LFP 24v 400ah batteries, a 3000w inverter and solar panels. If I am not running the AC or any kitchen or additional appliances there will be long times where there is nothing I need the inverter for. The refrigerator will empty the existing 12v AGM battery in 2-3 days.
I am thinking of ditching the 12v battery and running two feeds off the 24v batteries, one to the inverter, another to a 24v step down to 12v converter and then back into the existing RV converter box thus mimicking the feed from the 12v battery when there is no shore/inverter power. I am thinking this would be more efficient for long periods of time to convert from 24v to 12v and then right to the fridge and lights etc, versus leaving the inverter on and going from 24v to 120v then back 12v.
Does this sound like a reasonable approach, would there be any issues with the existing RV converter trying to charge what it thinks is a 12v system when I turn the inverter on? (I was just going to have the inverter feed the RV like it is shore power.) The existing RV converter is not tuned for LFP and also using a step down converter like: https://www.victronenergy.com/uploa...nd-12-24-DC-DC-converters-non-Isolated-EN.pdf . . . I am thinking would not accept current going the other direction.
Is this a good idea? (Thanks in advance for your replies.)
