I'm working on that. I have a shed in the desert ( southwest Texas ). It's only 8' X 12'. I picked up ( 3 ) 355W Poly Panels that will fit on the roof. They were $100 ea. and I couldn't resist. I'd just like to run a small a/c ( possibly 8 hrs ) and a small TV at night ( 4 - 6 hrs ). I haven't figured all that out yet but I'll need suggestions when I do. I don't even know if that's going to be enough PV.OK, an "Off Grid Solar Shower" is a start.
Now for PV, you need to make a list of your electrical needs, including type of load, peak watts, and watt-hours per day.
ThanksWelcome!!! Ask lots of questions!!!
Some panasonic window A/C units are about 600WI'd just like to run a small a/c ( possibly 8 hrs )
There's water for sale about 12 miles away. I have a 110 gallon tank on my truck. My shower is a propane tankless heater fed by a 50 gpm 12v pump. 12v battery with a 100w panel. I love my place , but it gets HOT in the summer. Going in October to insulate it.How do you get water?
I am definitely going to need a significant battery bank.
Where I'm located , believe it or not , it cools down pretty quick after sunset and the humidity is really low. I'm thinking the a/c would be turned off at this time. Draw on the bank would just be a TV , led light and a small 12v fan. I would say it's sunny 300 days a year. There is a fella in that area that building lithium batteries. What's the general feeling about those?Battery is the most expensive part of an off-grid system. Also the shortest lived, unless electronics turns out to be poor quality.
To me, the thing to do is try to minimize battery.
That can mean putting in excess PV (sometimes letting production go to waste), and using power when produced as much as possible rather than saving for later. PV costs less than batteries and lasts longer.
Also, cycling battery heavier and wearing it out sooner (I'd rather pay 1/4 as much for a battery and wear it out in 2.5 years rather than 10 years, get my money's worth sooner. That probably only applies to lead-acid, because lithium ought to last a decade of 80% cycling. So I wouldn't want to buy oversize lithium bank and cycle it less than 80%)
The question becomes, "What are the loads that must be operated when sun isn't out?"
You then need a system which regulated battery charging current to an acceptably low level, while delivering all available power to inverter. There are several ways this can be accomplished. Hybrids with SCC and inverter built in are one. Some SCC like from Victron can be controlled based on a battery shunt. AC coupled systems have a separate battery inverter.
Well , I'm kinda short on shade. ?Assume 5x surge for a second, so 3kW for seconds not 10's of milliseconds from the inverter.
A good 2000W inverter with real surge capability could do it. Not a lightweight one.
Lithium has its advantages. Depending on how low your night time draw, you might get away with cheap lead-acid. Figure out watt-hours needed.
I measured an A/C just as bit smaller.
Is 600w enough
I plan on putting 600w of solar panels on the roof of a small camper. The Panels will be able to tilt so I can get as much power as I can. My main use is to run a 5000 BTU AC tha draws 450w in the summer and a 500w space heater in the winter & a few little items like phones, tablets and led...diysolarforum.com
Anything you can do to reduce heat load, shading all faces of the shed that receive sun, will help let the A/C keep it cool.
As for PV, I'd think 3x what you've got, with multiple orientations.
