So everything I'm running now adds up to 70 watts, not measuring, just based on the ratings on the chargers and the string lights added together. I just find it interesting that this arrangement doesn't cause an issue but the fridge by itself does.
The fridge is an upright "Hanai" freezer converted into a fridge with a temperature bypass sensor, so its set to run at fridge temp. I just bought a kill-a-watt device (
https://www.amazon.com/dp/B01D1YA8G2?psc=1&ref=ppx_yo2ov_dt_b_product_details) to read the fridge watt since it won't be accurate to the rating as a freezer. It hits 70 watts at most and rarely kicks on the compressor so its usually reading 0. Maybe this reader isn't accurate..
Ive just been using an analog multimeter to check voltage. Clamp meter definitely looks like it could be useful for diagnosis. Thanks for pointing me to that.
