I have an electronics background, but new at solar. I want to do a small starter solar setup. Please see the attached sketch. My question is, if I use polarized DC breakers, is the diagram correct? My plan was to use them as disconnects/protection for the panel to SCC, SCC to battery, and battery to Inverter. The only markings on the breakers is a + sign on one terminal (top left corner) of the breakers. There is no other marking. From what I understand, I should connect the + terminal of the breaker to the supply side positive for each device. I realize the danger of incorrectly connecting a polarized Circuit Breaker so I want to double check before proceeding. Is that correct?
