Partsjockey
- Nov 17, 2019
- 66
I have 2 12v agm 290ah batteries in series for 24v. I want to but 2 275ah pre made batteries to replace the agm's will this be enough.
Thanks for the answer. I believe when they built this RV that was taken into account. This old girl is 22 yrs old. So I think I should be good for battery size. They are 4 EVE 280 ah batteries with it's own bms in a case etc etc. I guess I was questioning my decision because the batteries were not the same physical size as what I have at the moment. Now just need to get dc to dc charger for the alternator & adjust inverter.Microwave is a reasonable load for battery/inverter. Actual power draw is not same as rated cooking power watts, could be 1500W actual draw, so battery and inverter need to support that.
Electric stovetop is probably OK unless run for such a long time that it exceeds stored power.
Electric floor heating, what wattage rating? Space heating will run the battery down because it is a large continuous draw.
Washer dryer should be fine, but only for a limited time. "Ventless" is typically lower power than conventional. Some use refrigeration to condense, some use water (more common in single washer/dryer unit, hope it doesn't waste too much from your fresh water tank!). Some use fan and room air to condense, so wasting heat and heating the room. Dryer will be a significant power consumer.
Water heater also consumes significant power, but could be reasonable peak wattage.
Many RV appliances are reasonable only on shore power.
Multiple heating loads at once could exceed inverter capacity, and maximum battery current draw.
Only your personal usage will determine whether battery capacity is enough.
If you put PV panels on the roof, and enable water heater and dryer when sun is shining, might work out well.
Space heating like heated floor won't be practical from battery, could be OK while excess power from PV.
You need ratings of batteries, inverter, appliances to better analyze how much can be powered.
Yes that one, inverter is Trace SW4024, I don't know about the precharge resistor or even how to achieve it.
here is a decent chart of typical household item loads...Microwave is a reasonable load for battery/inverter. Actual power draw is not same as rated cooking power watts, could be 1500W actual draw, so battery and inverter need to support that.
