Donald Siegel
- Sep 24, 2019
- 78
In a simple low cost shed system using 400 watt PV panel, a single 12 volt 200 amp gel battery, an EPEVER 30 amp charge controller, and a 2000 watt inverter you have low voltage disconnect on the charge controller and inverter that kicks in at 11.1v, way too low to prevent damage to the battery. One option is to add a product like a Victron Battery Protect and set it to shut down the battery at 11.8v. So if the battery protect kicks in one evening because you left a load on unattended and disconnects the battery from the controller, the next day the PV is pumping power to the controller with no battery connected and cooks or worse. Alternatively you may be fooling with the battery cables and forget to disconnect the solar first, and cook your controller.
So can we automatically disconnect the PV as well when the battery disconnects? Can you add a (normally off) car solenoid in line with the PV circuit powered using the battery voltage tapped between the battery disconnect and the charge controller? So the battery protects disconnects the battery, it powers off the solenoid and breaks the PV circuit as well protecting the charge controller, let alone maybe by preventing a fire. Is this a good or bad idea? Is it a standard practice, and I just did not read enough?
