Chrisjg1973
- Jun 9, 2021
- 4
200 amp hour battery, 40 amp renogy charge controller, 1100watt inverter, 4 x 100 watt solar panels. The inverter is shutting down at times and showing low voltage, I noticed this only happens when the solar is connected and the voltage drops down. This doesn't happen when the solar is disconnected. It seems that the inverter is reading voltage from the charge controller and not the battery. I have a switch on the + battery lead then going to a bus bar. Everything is fused connected to bus bars. Could something be connected improperly?
