I have a remote off-grid system that from time to time has enough power drain and snow on the panels to cause the LFP batteries to shutdown due low voltage. When the snow melts and the sun comes back there is no good reason that the solar charge controller (EG4-6000ex right now) couldn't supply 48 volts and the batteries would come back on. However, the batteries and the charge controller remain at an impasse : the charge controller doesn't see the batteries as being connected since they have their discharge FETs off so the charge controller doesn't supply power. If either the batteries OR the charge controller would "wake up" from this situation they would both reconnect. However if the batteries shut down on LV I don't see it as their responsibility to restart the "conversation."
I'm interested in taking Signature Solar up on the trade in program and moving to the 6000xp. Does anybody know if the XP can work through this situation and at least intermittently put 48V on the battery bus even if there is no voltage from the batteries? I want the charge controller to start charging again whenever it can without human intervention.
I would consider this a requirement for my off grid solar charge controller so if 6000XP can't do it I need another solution or a different charge controller (could be a small one in addition) that can.
