If I divide two batteries each for one mppt, I am asking that these 2 batteries linked together to the inverter? I am confusingly
The PV side of the charge controller and the battery side of the charge controller really don't have much of anything to do with each other except that the load placed on the PV circuit, is correlated to the charge rate being set on the battery charger side (like a fancy variable buck converter).
I like to just think of a charge controller, as a battery charger (knows how to handle different battery types/chemistries and manage charging and maintaining a battery, without overcharging it)... But instead of using an AC input power source to power the battery charger, it uses a PV solar circuit, and it buck (down) converts it to maintain the required power that the battery charger side of it needs.
It can perform MPPT sweeps on the PV solar circuit (pull down voltage by lowering input resistance), which draws up the amps on the PV circuit, finds the maximum power point in watts, sets it there, and can pull best power as required (best mix of amps to volts ratio to get max watts), so it can get the battery charger side of it up to maximum rated amps output, or best amps for whatever stage it's in.
You can have a battery bank of several batteries (connected in parallel), and you can parallel in many battery chargers, it is fine. In this sense, the PV side of it doesn't matter, it is just a power source for its respective charge controller (battery charger).
Once all the battery chargers see that the battery bank is charged, they will all 'relax' their respective PV circuits (by raising the resistance in the PV circuit, in turn lets PV volts go high, and amps drop down to nothing), which will lower the battery charger output amps down to trickle.
Hopefully some of that makes some kind of sense.
