markhurley
- Mar 13, 2020
- 3
Are used panels any good?
How did you find them? I have been looking for local sources of used panels in the mid Atlantic region.I just made three purchases of four 245W panels in the last couple of months. These were all 30V grid-tie panels removed from a one year old reposessed grid-tie system. Each set of 4 for 220$. I checked each and every one before loading them onto the truck. They all appear to be in like new condition. I already have one set up and running, and they are producing power like they were brand new. I am just tickled pink!
Where do you live? It seams like Texas and California are the closest places and I'm in Tampa.I just made three purchases of four 245W panels in the last couple of months. These were all 30V grid-tie panels removed from a one year old reposessed grid-tie system. Each set of 4 for 220$. I checked each and every one before loading them onto the truck. They all appear to be in like new condition. I already have one set up and running, and they are producing power like they were brand new. I am just tickled pink!
It took awhile but I found them by checking craigslist and offerup on a daily basisHow did you find them? I have been looking for local sources of used panels in the mid Atlantic region.
Also I sourced these locally to keep the price down because shipping is a bitch , I had to drive a couple hundred miles but that kept the price down.Where do you live? It seams like Texas and California are the closest places and I'm in Tampa.
Thanks!Also I sourced these locally to keep the price down because shipping is a bitch , I had to drive a couple hundred miles but that kept the price down.
Thanks. I almost bought from them, but it would make the most sense if I need a larger number due to the flat rate shipping you mention.Santansolar.com routinely has 265w used panels for $50.
Shipping is expensive but I believe it is a flat rate so the more the merrier when buying ?
I have no affiliation other than as a satisfied customer.
I purchased 16 250 watt panels from Santan solar, the panels including freight to my local freight depot was $880
Here in Arkansas the largest snow I have seen is about 8 inches of wet snow. Something like that happens here on average once every decade. What I'm thinking of is a small solar shed, maybe 12' x 6'. The panels would be supported by a few 2x4 underneath, but no other decking. Down in the Arkansas I'm more worried about the shed toppling from thunderstorm winds than being crushed by snow. I'm just looking for a way to deploy more of these inexpensive used panels and have them serve a dual purpose for me.In snow belt country, you have to build for snow loads. Roofs need to be heavy duty so as not to collapse when they have a couple of feet of snow on them...solar panels alone can't do that...they can sit on top of a suitably strong roof, but they are not strong enough on their own.
I chuckle when I see a lot of roofs down south, they are light enough duty they wouldn't last one winter up north.![]()
