Compress or not, flexible busbar or not
My spacers are 3D printed. Probably don't compress very much.
Is there any spacers/insulators between your cells other than the blue 3d printed spacers that go across the top and bottom?
Yup, I’ve seen Andy’s video as well and I understand his thinking. But there’s other considerations. #1 time. Yes there’s calendar aging, but advantage/disadvantages of physical restraint/compression won’t be known for years yet. #2 if the manufacturers are recommending it and have data supporting it’s use, I’m not going pretend to know better. #3 from what I’ve seen so far, the 32 (302ah) compressed cells look fine and have excellent capacity.
I’m not running at 300kg (660lbs/12psi) but 550lbs/10psi). The cells are are close, no gaps between them and no appreciable bulge across the top. My cells had a 1/16” bulge and went away before reaching full force. I’m betting that most cells 280 and less will be flatter than the larger ones.
In response to #1; there is advantages known like reduced swelling in high amp demand situations. Disadvantage is loosening busbars/nuts/screws have been noticed when using solid busbars due to swelling/expansion contraction that is uncontrollable which is why welding the busbars to the cells is preferred and often done when compression is used.
#2 yes the manufacturers recommend it but I’d assume that recommendation really only matters for high amperage draw situations when there’s severe swelling possible. It’s been logically proven by Will and Offgridgarage that compression doesn’t matter for cycle life for solar storage.
#3 yes proper compression won’t hurt the cells at all if using flexible busbars are used. With compression and solid busbars the nuts/screws can constantly loosen and need retighten due to uncontrollable expansion and contraction. I’m not make that up. Several users have reported this.he flexible busbars you are using add a lot more resistance to the battery bank. How many amps are they rated for? Also then the bms balance wires would have to be attached to the cell terminals because you can’t tap those type of flexible busbars for the balance wires
1/0AWG is simply not flexible. Any smaller gauge wire is adding resistance to the system. Also 1/0awg is very hard to bend to go from cell to cell and causes stress/pushing on the cells terminals. Those laminated busbars that are supposed to be flexible (with the bend in the middle) imo are not flexible enough to make a difference.
Not sure you are referring to these laminated busbars but these are extremely flexible: https://www.aliexpress.com/item/3256803043965156.html
yes
3d printed PLA with 20% infill so very firm.
So then your busbars/nuts would loosen (if it is possible) with your compression and no space between the 3d printed parts. How long has this setup been supplying power to loads? How many amps has been going into/out of them?
Those flexible busbars are empirically infinitely better than my solid busbars in my build. I used to have problems with varying cell resistance requiring loosening and re-tightening my solid busbars (some of which became nearly impossible to remove due to expansion). Ever since installing those flexible ones, I've had zero problems. Details are in the latest posts of my build thread (in my sig).
The ones that @rhino mentioned above are the ones I'm using. Quite flexible.
We’re your cells compressed?
Yes I assume compression is recommended for all of these LIFEPO4 cells (unless cylindrical). But as Offgridgarage and Will explain in their videos and as I said above, calendar aging will be a problem well before degradation due to cycle life.. my main concern is if I don’t compress, will my cells possible become damaged due to not having compression. And have more so of a chance of cell damage due to CATLs being more prone to swelling.
All I can tell you is mine are setup like Andy’s and I have never had one swell yet. Some are 18 months old. YMMV..
Hence my comment that they will make custom for you. 1/0 is not very flexible, but 3 6ga. are.
Worried about cable stiffness? Think diagonally. The the short red ones are 2/0. You don’t want them straight, but with a bow. When you crimp the second lug on put the bow into cable to lock in the shape and make it more flexible in that range. Remember to keep the lugs rotated on the same plane, they won’t twist easily after crimping. You want to use fine strand cable like Windy Nation welding cable or the most flexible but more expensive Ancore brand cable. I’ve found found that Ancore or Selterm are the best lugs for the job and crimp down the tight with my dies( nice crisp hex corners). Just before crimping I do a very light polish on the inside of the lug to remove oxides of the tin surface or copper. Use 320 or finer Emory on a wood dowel, steel wool or Scotch bright. The idea is just to knock down only the high spots, remove oxides but not scratch it or remove the thin tin plate. A #2 is plenty for most needs but nothing beats the low resistance of a solid, tin plated copper buss bar(supplied).
Looks good.
How are you achieving that amount of compression and keeping it constant? I’ve read to much compression is actually worse than no compression. Having the balance wires rings on some nuts and not on others is making the connections from cell to cell different causing different resistance and different cell voltage readings with more one wire ring on some nuts, I guess that’s why I see a lot of the solid busbars tapped (you can’t with braided flexible) so the cells nuts can all be torqued the same without having wire rings on them, so every cell is supplying the same amount of power with same resistance and same bms voltage reading for each cell.. not trying to pick apart your setup, just trying to decide out loud what’s best for me
Yay! I actually saved my notes in case I wanted to build more.
Material List for:
Eight Cell Compression Module
(lithium "Squeeze Box")
Fits most 272/320 Ah Prismatic LiFePO4 cells with allowance for .045" silicone
spacers sheets on wide battery surfaces (9 places).
Home Depot 2' X 4' plywood Sheets, Radiata Pine 1/2"(.480) & 3/4"(.725) thick:
1pc Bottom 3/4" X 7" X 29-1/8"*
2pcs Sides 1/2" X 9" X 29-1/8"*
4pcs Ends 3/4" X 7"* X 8-5/16" (2per end)
2pcs Thrust plate 3/4"X 6-15/16" X 8-1/8"*
*Denotes surface grain direction. Doubled thrust plate has the only vertical grain.
Ends sit on bottom and between sides.
1 pc Spring, 634.6 LB @ .56" deflection
from MSC (mscdirect.com) PN 07661879.
1pc 3/8-16 four pronged Flange nut
1pc 3/8-16 X 3" Bolt, zinc plate (not stainless! it may bend)
1pc 3/8 fender washer, 2pcs 3/8-16 nuts
Grease for threads and washer surface.
Teks sharp point lath screws #8x1-1/4" to align while gluing.
Clamp up assembly squarely before gluing. Drill tight clearance holes through first side
and pre-drill small hole for threads.
Titebond 3 glue, re-coat edges after a few minutes soak in before assembly.
When done, protect with Minwax Helmsman Urethane 3 coats.
Sand between coats, warning very DUSTY!
"Large Silicone Heat Resistant Mat 78.7" X 15.7" (Amazon) (enough for two modules if smart).
Lightly spread a dusting of flower on sides of silicone to help it slide down between batteries,
Looks good.
You’re not picking anything apart, but making valid assumptions. That braided jumper looks cool, carries lot of current but has a major flaw of “cold flowing” and requires periodic re torquing, hence it’s got to go. I think another reason people are going away ring connectors/balance leads at the terminal is again, cold flow of that little soft crimp connector and it getting chewed up by the conical,spiral bottom of the flange nut. I replace all the supplied nuts with smooth flat bottom flange nuts. The ring connectors I use are Sopoby brand on Amazon. I discovered that they are actually brass, not copper (despite the description). They are much harder than copper and don’t cold flow. They are less conducive(only ever pull 4 amps) stiffer, easier to break with bending, harder to crimp and remain tight. Because of this I remove the heat shrink, crimp(if it’s a small wire, double it over) solder and use a clear flexible shrink tube with label printed number inside it. The combination of the hard ring terminal and flat bottom nuts seams to never move once torqued. I may even try a Belleville washer in the future if there’s enough thread.
Like Andy’s meaning that you are using solid busbars and have roughly a 1/4” of space between your cells?
If you are that worried about it go diagonal and use 1/0 DLO cable, it is very flexible and has a minimum bend radius of 4x it’s diameter. This actually makes things go easier not having to assemble for top balance and reconfigure after.
As for compression it is a no brainer especially for a mobile application, the cells have a lot of mass and will want to move which would put more stress on the terminals than the minimal expansion of the cells when using springs.
The way I understand the damage from expansion and contraction is when the pouches expand and contract with no compression the pouch layers can separate, by using compression the pouches have a flat surface to push against when expanding keeping the pressure constant across the face of the cell.
On my EVE LF280N without compression they are rated 2500 cycles @1c with compression they are rated at 3500 cycles. That is not a small drop in performance. With the newer EVE LF280K they don’t even rate the cells without compression.
Two questions, where the heck are you getting the DLO cable and what kind of diagonal jumpers are those?
I get the DLO cable from Skycraft surplus, the buss bar is Eriflex Flexibar and can be ordered in different amp ratings. I use a three layer 3/20/1 cut it to length and drill it.
Skycraft
Flexibar
ATM I’m going to use flexible laminated busbars to prevent the busbars loosening. That should prevent the bms from thinking the resistance of the cells is different than actual. Will also compress the cells to prevent them from delaminating, most likely without using springs. Unless someone can recommend a spring because I’m not intelligent enough to figure out what spring I need..
question about compressing with threaded rod, will all the cells have the same amount of compression applied to them? Is the difference negligible from the middle cell to the end cell?
Thanks for the info on the flexible busbars and cable!
I would use something like these. Four threaded rods and four of these valve springs are in the right ballpark for the EVE 280 cells, so if yours have similar requirements, the same should work well. The pressures within the pack should be similar.
