Don't know what happened to original response but I got the code and changed the code back to 1234 using old version and alls perfect got the cells charged up to 3.625 rested overnight and testing 1st one now with the ECB-A40L. Sadly I must have done something wrong or I have no idea what I'm doing a 302ah battery charged to 3.625 rested for 12 hrs and the tester shows at 35amp discharge Im at 3.21v (going to 2.8) and have only pulled 109.59 ah and 355.12 energy out of it man i hope its a long flat line???????? Thanks to all
Hi, just activated my new kk 200amp bms changed the password from 123456 to 000000 (same as my old Daly) all was fine for a short while, now neither password works, locked out.. Can it be reset? Help! Many thanks
There are TWO passwords on a JK BMS namely:
1. Bluetooth (for the mobile app to connect to the device) with default 1234
2. Settings (for user to modify the settings) with default 123456
