Hello everyone,
I just tested my new EG4 6000EX under load and the display doesn't show Voltage Out, Load or Output voltage on L1 and L2. The inverter was drawing 12.43 amps from the batteries. The load on the inverter was a full-size refrigerator, mini-freezer, touch plate lighting system, router and cable modem. Those devices were receiving power. I have the Inverter configured without an AC IN connection, the output is connected to a rotary switch to allow me to either use the Inverter or Gas generator to the 30-amp breaker on the service panel which is protected by an interlock. I had originally connected AC IN from a 30-amp breaker on the service panel just for charging but removed it, you can see that in the last image (that was a no-load test). L1, L2 and Neutral are on the terminals of the rotary switch and the grounds are wire nutted together. Thanks in advance.
