Adam De Lay
Solar Wizard
Error 61 is usually a battery communication issue.I'm running a single EG4 6000Wex inverter on 4 lithium batteries 100A each, after connecting the battery to the inverter the system worked for few minutes then started displaying 61, this happened twice and now the inverter is not displaying output voltage, please help me reset the AC output voltage?
If you are using EG4 batteries, try switching the cable around that connects the inverter to the batteries. The plugs of that cable are specific to the device they're plugging into.
